Hello, I am a noobie to boating but I am an ASE Mechanic. However I just bought a 76 Glastron with a 165hp mercruiser. I took it out and noticed that it did not shift into gear right away. I tore the lower unit off and noticed my shift shaft in lower unit is worn out to the nub. Do I have to tear the whole unit down to replace it or does it pull out from the top? Tried to get a manual from local library but no luck. Thank you in advance for your help.
