Hello there,
This may be a little long-winded, but I would like to hear your opinions on a few or all of the questions that I have. If you want to skip the lengthy story, continue down to my questions. Please read and post, I would really appreciate it...
1) Story/Diagnostis
I recently purchased a '66 Fiberform 14' boat with a '69 Evinrude Sportster attached. It was a Craigslist deal i couldn't refuse. $600 for boat/trailer (titled and registered with a year left on tabs for both) and motor. Was told that the motor ran great and it came with extras (new gas tank, new battery, hitch ball and lock, bumpers and more) so i got it. I gave it a quick over, changing lower unit oil (no water or metal, always a plus), compression check, grease/lube, some new gas...etc, everything looked good. I brought the boat out the next day and got it in the water. It started up pretty quickly, got it off the trailer and was off. I let it warm up a bit, listened, sounded good. I slowly made my way to the no wake zone buoys. Once out of the no wake zone I figured it was time to check this baby out. Got it in gear, eased on the throttle, then "Clunk", it popped out of gear with some grinding (motor still going, no prop movement). Hmm, that's odd, so i really eased on the throttle and it did it again, Dammit! Had to completely shut down the motor in order to get it to re-engage into forward. Went out, got the manual and proceeded with the teardown. At this point, I'm hoping at best that it's just a worn clutch dog, and not the forward gear. There was engagement under low loads/speeds, and broke loose a little over 1/4 throttle. Got the lower unit drained and off, no metal shavings (again, a plus). I went to remove the lower housing and of course, the previous owner stripped the head on one of the flat-head screws/bolts. Now I have to find a way to remove the stripped fastener. I have basic hand tools, but not anything to take care of this, not even a drill. I tried an impact driver, but it just broke a couple #3 flat-head bits and I kinda gave up for now.
2) QUESTIONS
a) Was this a good deal? Would you have bought or walked?
b) How would you go about removing the stripped lower housing bolt?
c) Do you have any experience working with these motors (lower unit)?
d) Is this a clutch dog problem or worse, dreaded forward gear ($600 replacement), or something completely different?
e) Do you have a lower unit (or lower unit parts) in working order that you would like to sell? (Any '69-'70, 18-20-25 hp evinrude?)
f) I have hull specific paint, but I want to go with a blue on top, What kind of paint (type and brand) would you use?
g) What are the 3 oar-lock looking mounts on the port side of the transom (see pics)? Swim step, kicker mount?
h) One of the spark plugs looks cross threaded, is it cheaper to have it/them re-machined or find a used/replacement head?
i) Any comments on the things I should look at/do/fix/renovate?
j) Opinions?
1) Story/Diagnostis
2) QUESTIONS
j) Opinions?
