Johnson48Lowe88
- Jun 8, 2011
- 9
I need help troubleshooting an issue:
I have a '91 Johnson 48 SPL. It starts right up, but idles a little rough. Also, it seems to have a minor misfire. It still pushes the boat in no wake, minimum wake zones.
However, when I increase the throttle to plane, to the boat will jump out of the water to go, but will suddenly lose its RPMs and go back to jogging. Also, when I am at about half-throttle the RPMs will suddenly increase and then subsequently decrease.
What I am thinking - issue resides in the carbs, gas/throttle issue, and/or power pack/coil pack. I recently purchased the outboard and the mechanic was suppose to ensure that the carbs were clean and the water pump was good, as well as wire the control box. However, I am thinking he may not have checked the carbs at all.
Where should I start? I appreciate any and all of your help.
Thanks.
Thanks.
