AKBASSKING
- Sep 29, 2010
- 29
These are from Boattest.com
How to Refuel Safely
1. Close all ports and hatches before refueling to keep fumes from the fill from entering the boat.
2. Ask occupants to stand on the dock before refueling.
3. After fueling is complete, open the engine hatch, stick your head down in the compartment and sniff for fumes. The human nose is the best fume detector.
4. Keep the hatch open and give the engine compartment time to dissipate any gas fumes which might be there. (I also check other fluids such as oil etc.)
5. Visually inspect for signs of fuel in the bilge, dripping from the fuel-fill pipe or at fuel line connections, of which there are usually a minimum of four.
6. When all looks and smells safe, turn on the engine blower and run it for 4 to 5 minutes, depending on guidance from your boat manual or the plate affixed next to the helm.
7. Start your engines. Then ask your passengers to board.
