OnTheWaterSC
- Jun 7, 2011
- 5
Hello Everyone! I'm new to the forum and just purchased my 1st boat last week. Here's a little history of my problem...I purchased a 16ft Jon Boat that was outfitted with a 1983 Johnson 15hp. The gentleman that I purchased it from said that he no longer had time to use the boat and it had been sitting for a while.
When I got the boat home the motor would fire up with no problems but ran a little rough. Having been told it had not been used, I took the carb off and sure enough it was a little gummed up. I cleaned the carb and re-installed it. I dumped the old fuel and replaced it with fresh gas and I replaced the fuel line and primer bulb from the tank to the engine with a new set. Running the motor in my yard it seemed that I had corrected the problems with the fact that it had not been used frequently.
Now...the next day i took the boat down to the river to try it out. The motor fired right up but when I tried to go wide open, the motor didn't seem to have the response that it had in my yard. The RPMs would flucuate up and down and never could get the boat on plane. After adjusting the knobs for idle and rich/lean with no change in the way it was running, I eased out on the choke and the engine came to life and the boat got up on plane and it was smooth as glass with no flucuations in the RPMs or anything. It ran just like I had just purchased a brand new motor. But when I pushed the choke back in or "off" it went back to running poorly.
I know that pulling the choke out tells me that it is robbed of fuel and running lean. I checked the fuel filter this morning and it seemed to be ok with nothing in the screen that would block fuel flow. I did notice that when it was running rough, I sqeezed the primer bulb and it didn't seem to want to open back up. It stayed partially collapsed after I squeezed it. I am absolutely new to outboard motors and just transferring my knowledge of ATVs and carburetors to this. What else can I check or what could be causing it not get enough fuel? The fuel tank itself is pretty old and that is next on my list to replace. Could the fittings that attach the fuel line be gummed up as well or is this not common. I have also checked my fuel lines for kinks and all looks good there.
What is really confusing to me is how well it seemed to run in my yard but not so much in the water. I know that the engine is under more of a load in the water but it doesn't seem to be starved of fuel when I run it out of water.
Thanks in advance for any input that you have to offer!
