DamianJP
- Mar 25, 2008
- 605
Still unsure of the year/model number, but I know it's a 90's motor.
Got the carb kit and water pump kit and started to do the water pump.
2 things are grabbing my attention.
1)The water tube came out still attached on the water pump. Looking at the schematics below it seems that part 72 is the upper water tube seal. If thats the case can it be installed without removing the powerhead? It still might be up in there but Im planning ahead if its not or if the condition is bad and it needs replacing. Mabey I can place the grommet on the tube and reinstall the tube into the powerhead (hopefully)
http://www.crowleymarine.com/johnson-evinrude/parts/49954.cfm
2) When I went to slide the impeller off the shaft it hit a "dirty" spot on the shaft and gave resistance and the shaft started to pull out. Is this what happens when someone messes with the Pivot pin?
If so how can I fix this?
See pics and video..
http://s281.photobucket.com/albums/...inrude 25HP/?action=view¤t=M4H01544.mp4
http://i281.photobucket.com/albums/kk233/damianjp_photos/Kens 90s Evinrude 25HP/DSC01547.jpg
http://i281.photobucket.com/albums/kk233/damianjp_photos/Kens 90s Evinrude 25HP/DSC01546.jpg
Thanks,
DamianJP
Thanks,
DamianJP
