84 evinrude 4hp
huntbirds
I have an 84 evinrude 4hp that doesn't go into high speed. I have good gas going to the carb. as i put a clear tube from pump to carb and no air bubbles. Next I cleaned the carb, checked the float and al seems good there. So when I run the motor, it goes fine in slow speed, but when I throttle up it goes faster but not all the way. Maybe 50%. Then every once in awhile it revs up for a second then backs down tro the 50%. Any help out there?
Daviet
Re: 84 evinrude 4hp
Compression ok? Points clean and adjusted properly? Plug wires and plugs in good shape?
High speed nozzle and orifice cleaned when you rebuilt the carb?
huntbirds
Re: 84 evinrude 4hp
Compression seems good. I had new pugs put in by a mechanic recentley so I assume thats good. Plug wires look ok. Is the high speed nozzle and orifice that little tub inside the carb with two small holes in it? If so, then it has been cleaned.
SolingSailor
Re: 84 evinrude 4hp
Possibly running on one cylinder? Check by pulling one spark plug wire at a time, then replacing. If pulling one makes no difference, that cylinder is not working.
Daviet
Re: 84 evinrude 4hp
It sounds like you are dropping a cylinderunder load. You could use an inductive timing light to check spark under load and see if the ign system is working properly.
Rick.
Re: 84 evinrude 4hp
When it isn't running well, pull on plug wires (be careful) one at a time to see if your only getting spark on one cylinder. They run very well on one but lack top end. If spark is good I would suspect the carb. isn't clean enough. Best of luck. Rick.
Daviet
Re: 84 evinrude 4hp
If you don't have spark on one cylinder, it COULD be a coil, or points, or condenser, or plug wire, or plug on the cylinder that is not firing.
huntbirds
Re: 84 evinrude 4hp
When I had it in a bucket it reved up fine but under a load, in the lake, it would not ramp up. Only about 50%
Daviet
Re: 84 evinrude 4hp
They will rev up in neutral, on one cylinder, a bad cylinder will show up under load.
