mjc_lakedweller
- Jun 7, 2011
- 4
Project with 1973 Larson shark and 73 Merc almost done. Thing is that I am having trouble with throttle cables attaching to motor. I know how the brass barrels fit and how to adjust beginning in Nuetral. However, call it a brain fart, but cannot get these cables to connect to motor properly. The lower cable (see pics) will not go on due to the set screw that holds the cable in place is sticking out just enough to prevent me from putting over bolt. The upper cable whch gets attached to throttle arm I am missing the two set screws and inside threaded collar part. Sure I can buy new cables but don't like to mess with the control box if I don't have to. Any suggestions out there?
