4.3 mpi wont start after setting
acwelch
Looking for some advice on this problem. Found a couple post similar to this problem. will give some tips a try but i would like to pick some moer brains first. this problem didnt start until i changed the water fuel seperator. this is a 04 merc 4.3 mpi 220hp in a tahoe q4. they gave me a longer filter than what came off is this a problem? installed primed pump ran with muffs. launched at lake took a couple of times to start. boat ran great for couple of hours with multiple starts. shut off to eat lunch about 30 minutes. it wont start. acts like it wants to start but then dies. spitts and sputters and pops. starts and idles for about 3 minutes then dies. same thing over but no starting at all. mechanic comes down after a couple of hours replaces relay starts right up runs good. go back to lake next weekend starts right up runs great all day same thing after shut off for about 30 minutes. checked the relays with meter all of them good including the replaced one he took out i kept it. now changed filter again to the same one came off same symtoms again. fire away guys any suggestions or help would be great.
Don S
Re: 4.3 mpi wont start after setting
If all you did is changed the filter, get the right filter and try it.
acwelch
i got the right one and put it on still have the same symtons could i have an air bubble or maybe vapor lock or maybe pump is going out out just seizes when gets hot. maybe not pumping the right pressure 4.3 mpi will not run with less than 40psi but shouldnt it at least start on low pressure. would you recommend just replacing the pump.
ryanr623
I wouldn't replace anything without diagnosing. Check your fuel pressure. Autozone rents the gauges free.
Also, let the boat idle for a couple minutes berfore shutdown and leave the engine cover off after shutdown as well. Try to start again after 30 minutes.
