I have a 2002 Crownline 202 BR with 5.0 GL Volvo Penta SX outdrive. I pulled my boat out and trimmed the outdrive down to check fuild level and about 8 oz of gear lube pour out on the ground. My question is where could it be leaking from the 2seals on the carrier bearing or some where else. Also if it leaking from the bearing carrier what is the meathod for removing this from the lowr unit.
