gophernorsk
- Jun 7, 2011
- 2
My motor (4 yrs. old, moderately used/6-7hours a day-5 days a year) will not start by itself when in the water but will sometimes when out of the water if i help turn the propeller first. When in the water it seem as if it does not get enough electricity to make it run. When I have it out of the water and turn the propeller with it turned off I can feel a slight even resistence in the propeller, as if brushes (that is if there are brushes in motor-I'm not sure) are in contact with something orr perhaps a ball bearing is worn. It is only a very slightly noticeable resistance but I feel it is not right. I have also read that a maintence issue is vacuming/blowing out carbon dust from the brushes that has accumulated in the motor-comments?
I have had th cover off the top and can see no problems there, nor in the handle contact.
Thanks.
Thanks.
