I am stuck in the removal or the what i think is the (Driveshaft) (i work on cars) but a tech said to remove the 6 bolts behind on the back of the upper unit. I did and ended up removing the entire lower unit. but the upper unit with the other end of the drive shaft comes out abou an inch and then wont move anymore. How does it coem out? Does it really pull off the flywheel?
