erosenwinkel
- Apr 22, 2011
- 130
Went out on the river with a friend to adjust the idle on my 125hp Force outboard (1258x5a). The engine runs (what I would consider) very good with the needles out 2.5 turns. When I turn them there doesn't seem to be much difference in sound. 50:1 fuel mixture. At idle (850 rpm or so) when I slip it into forward, idle drops to 550 or so. However, if the cowling is on, engine will stall. With cowling off, engine will never stall. With GPS, 37 mph top speed (18 1/2' Bayliner Capri) with cowling off and 34 with cowling on. Not enough air? I adjusted and sync'd carbs and they are as close to horizontal as I can judge. I can raise idle higher than 850 (each rotation of the linkage arm gives me approximately 150 more rpm but is that a good idea. For whatever reason, I can only pull away from the dock without killing the engine 20% of the time with the cowling on. Kind of dangerous and loud and hillbilly without it.
What am I doing wrong.
