Okay, this is my first time posting on iboats even though I have answered many of my questions just reading other people's threads.
I have a 1985 Chris Craft Viking with a 305 Mercruiser v8. All together the engine runs great, the only issue is that after it has been running on plane for a while the engine then stalls and will not start. After the boat sits for a while the engine will start right up and runs great until it has been on plane again for a while. I can start the boat in my driveway with the muffs on it and it will run great for hours even when I give it some throttle. A prime example is last weekend I put the boat in and drove around for over 45 minutes at a slow speed and it ran fine, I then cruised for about 10 minutes on plane, after this i drove another 30 minutes at a slow speed, once I tried to go on place for a second time it ran great for abou 3 minutes and stalled out like it was starving for fuel.
I have replaced the fuel filter and confirmed that there is no water in the fuel. I think it is possibly the carb getting clogged up or the fuel pump starting to go. Just wondered what anyone elses thoughts on the situation were.
Thank you!!!
Thank you!!!
