Re: lower unit 20 or 25" whats the differance?
Definitely got a longer driveshaft but I think they are pretty much the same at the linkage meaning the shift rod should fit right into your motor.
Somebody needs to correct me here because there's a really good chance I'm wrong, but I thought the extra length was all in the midsection. Since you're not replacing the midsection, you should be able to use your driveshaft and shift rod in the "new" lower unit. It'll be a little bit of a pain getting the shift rod lined up, but it's been done before.
