HONDA 90hp TRIM GAUGE
sfmaster
hi,
I have an honda 4 stroke 90 hp (1997). I'm having problems with the HONDA TRIM GAUGE. I turn the key (power) the guage needle moves, but when I trim the engine it doesn't level out. I leveled the boat out, while on the trailer, but the guage needles stay down. Do I have to be on actual movement or does the engine have to be on? I don't have any idea how the guage should work? So I really can't tell if its working or not. Any help on this matter?
Thanks!
AGENT 37
Re: HONDA 90hp TRIM GAUGE
The trim position sender is probably stuck in the down position on the engine bracket. Find it with the engine tilted up and see if you can get it to move, then actuate with your fingers, clean, and lube it.
