Bigdave196
- Apr 13, 2009
- 120
Ok, Got the boat out on the water yesterday for the first time. Felt good to finally be out on the water this season. Few things I noticed.
First off, there is no way to control the engine RPM's with out being in gear. The throttle control doesnt have a button to push, nor does it pull out to dis-engage the shift lingage. Please help.
Second. when i disconnect the TBI linkage and manually controll the TBI the motor will rev easily to 5500rpms, With a 17* Solas 3 blade prop on a 20'6" open bow boat I could not get the motor past 4400 rpms with 3 of us in the boat, all under 200 lbs. Speed in unknown because it doesnt work at this time.
Boat smells like its running rich and there appears to be excess fuel going into the TBI from what I remember my older truck using. Going from an idle to WOT the boat bogs down considerably until you back off a bit to let the engine speed up.
Thank you in advance.
Dave
I am at 4500' elevation.
Dave
