I have a 1984 Merc 90hp on a 1984 Glastron SSV-151. I'm not sure if it is the original motor on the boat as I am the third owner.
Motor is running fine, but I cannot get the boat past 32-35 MPH @ WOT regardless of where I set the trim. Everyone who has seen the motor / boat on the water has acted a bit surprised when I told them the top speed. The motor is currently mounted using the second set of holes from the top of the bracket.
Prop is a quicklsilver prop with a 19" pitch. One guy called it a "power prop". It does have a decent hole shot. Any recommendations as to the prop pitch / motor mounting that will help with top speed?
Thanks!
Thanks!
