Re: help!!! i need a points gapping tool
jb,
thanks, i have a feeler gauge. i had talked to a boat mechanic and he said i needed somesort of gauge to correctly gap them, can i just use a feeler gauge and gap them to .20? i was just going to take some pictures of the points before i took them off to try to realign them. i have seen pictures of a card with marks on it you put behind it? i have no upper power and i was thinking im running on three cylindersi can push te throttle all the way forward and attain about 10 mph i know this engine should have more power. or do you think it is linkage problem? if you get spark to all cylinders is your distributor working right? thanks
