G
Guest
Guest
What is the best material to use to replace the engine mount stringer??
Solid wood, plywood or composite? I need to fix my left side one that someone has fixed with piece of U shaped metal over the rotton one with 5 through bolts. I know that this side gets all the lifting torque as the motor rotates under power so I want make it good and strong.
