no1ditchdigger
- Jun 2, 2011
- 9
See attached photo. I am in the process of trying to locate all the hoses for back flushing sea water system to find stoppage. Main problem outlet hose on sea water pump blew off due to stoppage in outlet line. This photo of the oil pan and bottom well shows the engine oil drain line and a clamp that someone else dropped, at least I hope it?s not off of something important, but guess I will find out when get it all back together and then there is that piece of don't know what with a black line going to it. Any ideas what it is and is it suppose to be there? Second question, does the oil slime on well bottom and walls look normal or has there been a problem in past?
