Re: Trying again on prop question - more data this time
Since had a pretty good all round prop in the Turbo 3 blade (with vent holes), I decided to really focus on low speed handling and pulling out of hole ... got a QST 5 (High Five) and ran it yesterday with both 5 blade and 3 blade props and collected some data:
Calm water, about 80F, driver plus one passenger, center glass (bowrider) open, with GPS.
QST5
2.5-3 sec hole shot (just moving for steerage then full throttle, full trim down) until bow dropped to plane. Boat didn't labor to get up and then bow down, it just sort of popped up and then flattened. Bow still rose, but not as much and for not as long. Put the passenger in the back and wasn't much difference.
Yanking it around at very low speed, it just sort of hung on the prop without fuss at very high turn rates, don't think I ever got it to cavitate - planes down to around 14-15 MPH and then slowly dissolves off plane
Very little porpoising at higher speed trimmed
3000 RPM trim down (21.3MPH), trimmed a bit but maintaining 3000 RPM (21.1MPH) ... slip 28.6
4000 RPM trim down (32.2MPH), trimmed up a bit more and pulled back to maintain 4000 RPM (32.8MPH) ... slip 19%
4500 RPM trim down (36.7MPH), trimmed up a bit more and pulled back to maintain 4500 RPM (37.7MPH) ... slip 17.3%
WOT was 4800 RPM trimmed down (39MPH), trimmed up a bit more and let run to WOT at 5000 (I know is over RPM) was 42MPH ... slip 15.5%
QST not finished nearly as well as the Turbo - (looks like the blade edge had been roughly ground down and left unpolished) but probably is better value priced since I think I spent close to $400 on the Turbo over 10 years ago
3 Blade Turbo
5-6 sec hole shot, bow comes way up and hangs there for about two seconds and then moves rapidly down. Much more dramatic behavior
Yanking around at low speeds and high throttle can induce cavitation without too much effort ... doesn't hang on the prop the way 5 bladed QST did
Easy to get it to porpoise at higher speeds trimmed up
Forgot to check loss of plane speed, but was higher and much more dramatic coming off plane
3000 RPM trim down (24.5MPH), trimmed a bit but maintaining 3000 RPM (24.8MPH) ... slip 17.8%
4000 RPM trim down (35.5MPH), trimmed up a bit more and pulled back to maintain 4000 RPM (36.5MPH) ... slip 9.5%
4500 RPM trim down (40.4MPH), trimmed up a bit more and pulled back to maintain 4500 RPM (41.4MPH) ... slip 8.3%
WOT was only 4600 RPM trimmed down (40.6MPH), trimmed up and let run to WOT at 4790 RPM was 44.9MPH ... slip 5.5%
Ha - so much for the 50 MPH "indicated" on the speedo! Speedo about 10-15% off ... pretty typical, I guess.
Do the slip rates make sense?
So, net difference at something approaching a trimmed up cruise speed is about 4MPH and max speed at trimmed up WOT (4800 RPM) is about 5-6 MPH difference. I'll try the QST5 next week on the lake with skiers and evaluate it further.
What do you guys think?
