Boat quit pulling
jatsfirebird03
had my 1996 capri 1750 3.0 mercruiser out today,about 3hrs into the trip half throttle the boat quit pulling. we throttled down and limped it in. it will pull very slow but put any throttle over no wake and it wont go,its like something is spinning but not turning the prop. any help would be very appriciated. thanks
Don S
Re: Boat quit pulling
Since you didn't mention any smell of burned rubber, I would suspect a spun prop hub. Take the prop to a prop shop and have it checked out.
odie241
Hi,Welcome aboard!!!!!!
Sounds like you might of spun the prop hub,
Hahaha Don,you type pretty fast =)
jatsfirebird03
so taking it off and checking the inside prop splines are stripped? so hopefully not too bad?
odie241
on the inside of the prop itself is rubber,thats probably what went bad.If you call your local marine store,they can re-hub your prop for you,and even check it
jatsfirebird03
Not the prop hub. The guy at the marina said it sounded like the engine coupler went bad. Does that sound right? Maybe something smaller,not so hard to fix?
Don S
Did he even look at the prop?
Yes it could be the coupler. It costs more than a new prop, and you have to pull the engine out of the boat to replace it.
Don S
What rpm is it idling at? That may be why it won't shift.
dingdongs
can you upload a good picture of your prop splines.as don said the engine will have to be pulled if its the coupler.its always best to have a couple of props anyhow but if u have no splines left it will never be able to exert a load again.lots of props on ebay if you know thats what failed.
