We have a motor that is need of a propeller. After reading the internet, there is conflicting information. What is the correct propeller that we need? Diameter? Pitch? Model number? Any idea where we could buy one? Thanks!
59 brochure indicates 8 1/4" X 8 1/2" was standard prop.Your final choice would depend on the boat and typical load you would carry. Diameter is a secondary consideration if the prop is listed for your motor the diameter will work. There are 4 sizes available here at iboats Do you have a prop now? We'll try to get you get setup if you tell the details about your boat the typical load and activities.
