I am having performance problems with my newly purchased 1980 25HJP Johnston outboard. When the engine is cold or just starting out on the lake it runs fine (lots of power) but then when the engine warms up (3-5 mintes later) the engine bogs down (still runs) but seems to run on only 1 cylinder and idles fine in neutral. There is new mixed gas, new plugs, new fuel line from tank to motor, fuel filer is clear and clean, the water intake is not blocked, lean/rich setting has been adjusted. What next???
Also I have water spraying from the 2 exhaust ports (is this normal?) on the back of the motor as well as from the tell tale hose. HELP is appreciated!!!
