I have a 1999 7.4 MPI
Had engine replaced ( Michigan Motorz Reman long block ) by a Mercrury Mechanic. Change out went well however engine now runs very rich. So much so they will not release the boat to me for fear of engine damage. When they rev the engine and bring it back to idle it stalls.
Summary of engine info:
New motor is Michigan Motorz 7400RRR
existng engine ser # 0L077447
fuel pump replaced 2007
Changes during troubleshooting.
No error codes
Eng temp sensor normal and reading correctly
New Map sensor
New fuel pressure regulator ( manifold vacuum only at 12" at idle )
New plugs
Injectors cleaned and tested
My mechanic has come to the end of his patience and does not want to spend any more time on it. I will say I feel he has been very fair just does not know how to go forward.
No error codes
New Map sensor
New plugs
