First post, but I've been following for awhile.
1) Performance issue you are trying to correct.
A) At WOT I get 4000-4200, won't plane for quite awhile 20-30 seconds/getting roostertail like wake behind the boat, Plan on using a for watersports but don't know if I can get out of the hole. My prop is in rough shape so I need to know should I get the same one new or change.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
Michigan 031027
3) Current prop diameter and pitch (required).
13.5x23
4) Wide open throttle RPM and speed with an average load (very helpful)
4000-4200 w/ 3 pass of total 520lbs
5) Engine/drive make, model, year, and HP
A) 1996 mercruiser 4.3 alpha one gen 2 outdrive
6) Boat make model, year, length and weight
1996 maxum 1900sr2 18.5ft about 2300lbs
Thanks!
Michigan 031027
13.5x23
Thanks!
