boatdrinks554
- Jun 4, 2011
- 4
Im pulling out my hair trying to get to the bottom of this. 90 percent of the time the motor starts fine and runs perfectly. Then after an hour or so of pulling wake boarders or just running around the lake the engine suddenly stops as if the key had been turned off. It will then crank but not start, then after letting it sit for halve an hour or so it may start right up with no problem only to stop again. Im thinking it maybe heat related and something going on in the ignition system. I've down loaded a few shop manuals, but im trying to figure out how to proceed and if anyone else has had this happen before. Plus because the problems intermittent trying to trouble shoot is unusually difficult.
Its a 1992 Mercury 90hp 3cyl.
