hi new too this forum and new to boats altogether. including motors.
picked up a this 1971 4hp 4106D for $300 which in my area seems like a good deal.
was used twice in 10 years and apparently serviced up 10 years ago. got it to start after 9 pulls when i first bought it. quickly realizing it was overheating. so shut it down, replaced the impeller and got that sorted out (lubed and regreased as i went). THEN wouldnt start at all. i just did a carb kit on it except for the float because its on order (it was floating fine still it seems) i set my slow and high speeds too joe reeves recommendations. it wanted to start almost every time i pulled it and finally after about 7 times it started. it ran for about 3-4 minutes and seemed fine until it stalled (i did forget too push the choke back in after it started)
then i tried to start it again about 7 more times (wasnt attempting to start) then the spring anchor on the pulley broke (btw i had serviced the starter and regreased and new rope etc)
sorry this is long winded. i need to know the part numbers for the pulley since spring anchor broke off. and the plastic idler gear as well. also the plastic throttle lever as its slightly warn. and any advise as too why it stalled (was it the choke not being in?) and any advise as too how i can get it to start on the first pull?
gas is mixed 50:1, new sparks gapped 0.030, i have spark on both i checked.
any info is really appreciated ...
