Over oiling
GregZ
I have a 1993 Yamaha 2 stroke 115
The oil will not stop coming .
I have replaced the float in the motor and the sending contol unit . yet oil keeps coming into the motors oil jug on the motor WHAT DO I CHECK NEXT?
99yam40
Re: Over oiling
measure the voltage to the oil control module , I believe if the voltage drops too low it will keep the pump turned on
kenneth80
Re: Over oiling
I have the exact same problem.
My battery is fully charged but the problem still exists.
Hopefully someone can give us a lead..
99yam40
Re: Over oiling
have you thought of measuring the voltage as I said? A charged battery does not mean squat if there are connection problems
or maybe starting your own thread with all your info as the top posts ask you to
kenneth80
Re: Over oiling
99yam40, the great Rodbolts successor, dont do the mistakes he did...
If you cant lead us anywhere then just leave it..
And if you look a little closer i have given a more detailed description of my problem a little further down here..
I thougt you were in full control of whats going on in here!
GregZ
Re: Over oiling
Ok You guys I just want my problem to be fixed ...Thanks 99yam40 I will try voltage test . I am not really a motor savy guy.
So lets just post ideas about fixing my problem .
Thanks Greg ><>
