i dont know what kind of problem i have . the engine will start and run fine i can get to where i need to go when i 1st put it into the water . so when i get ready to go to another spot after i have turned the engine off the engine will start and run fine but when i put it into gear to take off the engine will lose power and start running rough , the kicker is that i can push the trim button up or down and it will make the engine run fine but you let the trim button go it will bog down again . ican play with the trim button for about a mile and it will start working without having to play with it. i can stop again and turn the engine off and i have to start all over. any help on what to look for or at i would appreciate. i have looked for shorted out wires at the controlls but couldnt find any.
