Have a 1977 6hp Evinrude motor, Model# 6704M. Originally it did no produce a spark and replaced the power pak and two spark plug coils. Now it is getting a spark but still will not start. I have sprayed starter fluid into the carburetor and tried to pull start it, and still will not start. Last outing I had was last fall and the motor just quit running and would not start again. Never had any leaks in the lower unit, water pump was working good that outing, I always make it a point to make sure water is pumping out of the hole. Any ideas or suggestions what to do next? I have a good water pump, good spark plug coils, good power pak, very good spark to the plugs and starter fluid does not help.
