BBC , green wire to alt ???
old bird
While putting things back together I noticed a green wire going to the alt. not hooked to anything. ? Didn't see anything to hook it to. There are 3 wires to the alt. Red, Black, and this Green wire. Where does it go ???
Thanks
Bt Doctur
Re: BBC , green wire to alt ???
not knowing what the alt is on makes it hard to answer.
CobiaXL
Banned
Sure does...But Ill make a guess and say its for duel battery hook up :)
check this pic out,it might help
Don S
There are no green wires on Mercruiser alternators.
EDIT:
Looked at your profile and see you have an OLD BBC, the green wire is for the temp sender.
If you put your full engine information in your posts, it would make replies a lot faster and more accurate.
old bird
Thanks for the replies, not easy with no info.
I know better than leave out the pertient info to my boat. Dah??
I'll check for some id. on the alt.
Larry
