Renegade 2
- Dec 15, 2010
- 4
I have a 1993 90hp Johnson, Model J90TLETS. I am putting the lower unit back together and need to know which way the ring that the prop shaft carrier bolts to goes in. Should the side with the part number stamped into it face the prop, or should the numbers face forward. I think the nubered side has counter sinks on the bolt holes. Also does this ring go in before the snap rings are installed. Manual is not real clear on this.
