Re: wather from thermostat???
The cover should be fine. The hole permits the atmospheric pressure to equlize around the pressure relief valve. Possible the rubber seal (diaphram) from the pressure relief valve has a hole in it. The internal parts are fairly inexpensive. In addition to a new cover gasket, I'd probably put a new stat in too, just for good measure.
