skinnywaters
- Jun 3, 2011
- 3
ok, riddle me this...just picked up an 81' 25hp mariner (yamaha made though). lower unit had bad oil seals. took it apart and replaced the seals. did an air pressure check and it most certain held pressure. actually blew the top seals out like a champagne cork. Re-set the top seal housing and put the lower unit back on. Dropped it in the barrle and guess what, milky oil almost right off the bat. Now, did see the milk draining out of the weep hole in the bottom where the gear control arm would be entering the interior gear housing. I can not find a good exploded diagram of the lower unit, but i assume that there is a seal down there also since water does get down there. how the hell do you get to that seal? do i have to take the whole lower unit apart?? and why did it allow so much pressure with the air and not leak or gurgle?? can anyone help me?
