i get spark out of all three individual coils at the end of the spark plug wire for a sec and a half. then it quits on all three. The Symptoms: noticed lag in the (out of the whole performance) also w.o.t. was only 4000-4200 rpm. Fuel has small water droplets in fuel sample, but is clean strong smelling. treated with stabil. i pulled top carb from assembly and pulled off the bowl to view inside of carb. it was clean as a new one. compression was 122 p.s.i. across the board. what does it mean for the spark to quit like that, and would this cause the motor to run at only 4000 rpm and lag/plow getting out of the whole like it does. Thanks
