I have (2) 90 hp 4 strokes. I just replaced the impeller on one of them because the coolant stream is not as strong as the other motor. Found the old impeller in good shape but with a busted gasket on the housing. *REPLACED* Fired it up and still pee-ing the same as before. I need to know where the thermostat is located or what might be the problem?
