Re: Retrieve view download runtime data from honda engine (BF115)
Well ,lets backup a moment.I was under the impression that this was a unit in use and you were curious about use history.Honda may well have upgraded that ecm to communicate with that hds but if they have they are not sharing that info with dealer support.Currently the 60-225 efi models with the exception of the 115 /130 will scan.Easy enough to tell.Remove the plastic electronic cover and look for a red connector that is plugged only into a cap.No red connector,no hds.
