Columbia Fishin'
- Jun 1, 2011
- 6
I'm a noobie in the outboard world and have a couple questions about my Johnson 25 horse. The motor fires up by the second pull and idles great. I'm pull starting because when I try the electric start the solenoid clicks but the starter doesn't kick on. Ocassionally the starter will come up and start to turn but will immediately stop and never actually turns the flywheel. Is this the starter that's the problem?
The other bigger issue is when I have it in gear regardless of the speed about every ten seconds the motor jerks. It does not pop. The best I can describe the sound in text is rrrrrrrrrrbumprrrrrrrrrrrbumprrrrrrrr. Something like that Any advice or wisdom would be greatly appreciated. Thank you?
