JohnnyB021
- May 19, 2011
- 3
I have successfully changed the water pump and am now trying to re-attach the lower unit, but when inserting the shift-pin I cannot hit the hole in the upper part of the shift rod to connect it to the shift linkage. Is there a trick to making this blind connection? I figured that this connection needed to be made prior to attaching any of the bolts in the lower unit...is this correct? Would sure love some tips on this one....thanks.
