First time boater. Had the boat on the lake under heavy load (waves). Lost power and heard rattle (almost like metal banging around) in motor. Motor stalled out. Got home and checked compression. 135, 125, 20! Pulled the head to replace gasket and #3 cylinder has a different color, ash color (gray) with corrosion. Replaced gasket, still not enough pressure to start. pulled panel on side of block and the rings look ok. What could cause low pressure like this? I want to replace the piston, do I have to pull apart the block or is there an easy way? Does this even sound like a blown piston? Thanks. Sorry if these are dumb questions, but I am really excited to fix this and I have nothing to loose.
