Re: resistive ignition wire
I think Bob is referring to the ballast resistor, not a resistor wire.<br />It's been so long that I've done anything with points, I'd have to look back at my 1975 merc wiring diagram to be sure, but I think the resistor wire runs to the points from the negative side of the coil, and the points make the connection to ground. The purpose of the resistor wire is to limit the current going through the points, which as they open and close make the coil fire. The points can only handle a couple amps of current, any more and they burn out prematurely.
