fshrgy99
- Jun 4, 2010
- 69
Hi please advise!
owned for 1 year and had tons of trouble last spring till i discovered fuel line gas/air leaks (thank you marine doctor!)
-fogged in fall and drained fuel tank on boat
-disconnected vro last week and filled tank with 90 liters gas mixed 50:1 and 1 can 'sea foam'
-after priming bulb will run for 20-40 secs then miss and stall,prime with bulb,repeat....
-fogging oil is now burned off but motor will not remain running
-have removed gas line at vro and checked fuel fow and bulb ...seems ok
-sparkers were cleaned and look ok (but wet)
-if I continue to pump bulb motor will stay running
do I need a fuel pump or carbs cleaned. how do i check?
all input appreciated
Dennis in Kitchener On
