Haywood123
- May 10, 2008
- 64
I just bought a boat with this motor. I mixed my first gas tank 100:1 just to make sure the VRO was pulling enough oil so for a while I was running it a little oil rich, but that gas should be all out and I should be running straight gas (and a little sea foam) right now.
When I first start the boat, it starts right up, idles smooth, goes into gear great, takes off perfect, but after running it for a mile or so, it will kill when I decelerate to a stop. After that it wont start with out some throttle and then once it's running it will often kill when I go to put it in gear and when I do get it running, it boggs way down when I try to give it some power. Eventually if you really, really ease it in, the RPM's will gradually go up, almost like it was flooded out.
When I pulled it out of the water, I tilted the motor up and some gas poured out of the motor housing. I pulled all of the plugs (didn't check for spark as a storm was moving in) and all 3 plugs on the left were wet and black and all 3 on the right were dry and clean.
I am a little intimidated to work on this motor by myself, but is there anything off the top of anyone ones head I should look for, before letting a professional charge me to take a look at it?
