Smartcraft Help - 6 Pin Connector for Fuel Harness
jriptide
My boat is powered with a Mag 350 MPI 2006 Mercruiser, I have installed smartcraft gauges which work with the exception of the fuel gauge. Hence I now need to hook up fuel sender to the system using the following harness 84-859743T03. I have searched the engine and can not seem to find the 6 pin connector that the harness attaches to. I have found two flat connectors near the coil one for fuel and one for paddle wheel\temp. But the fuel connection does not match the 6 pin connector on the harness. Assuming I have the right harness for this engine can anyone advise me on where on this model of Mercruiser that conection should be located?
Some additional information - I went to my local dealer who assured me the 84-859743T03 should work for my engine, however on the mercruiser parts database this is listed as an outboard version of the harness. The mercruiser version was listed as 84-859743T04.
