impellor/ peehole expelling smoke instead of water cant b good
perks69
HI GUYS got a mercury 60 3 cyl 2 stroke on simms super v me n mate fitted new trim motor cleaned carbs compression tests new plugs lower oil change done ourselves took her out today ran lovely when we came back to flush out engine the the peehole had a heavy stream of smoke i know the impellor has not been changed for a least 3 to 4 years does it sound like the impellor has just siezed and melted can that happen just like that any help much thanks
ajgraz
Re: impellor/ peehole expelling smoke instead of water cant b good
Smoke? Or steam?
perks69
i think its steam pretty sure
perks69
dont understand how can b working 1 hour blasting out and next hour steam instead n not a drop
Don S
Replace your impeller. A plastic bag in the water has taken out more than one impeller.
perks69
ok thanks for but can u explain why its pushing steam out
Sunfish12
It's pushing steam because it's REALLY hot. Check your compression to make sure gasket is good. Then pull lower unit, change impeller, and spray garden hose up the water tube to check for flow. If the impeller was disintegrated then pulll the thermostat and blow water down to try and get rid of any impeller particles before you put lower unit back on.
