tompowers85
- Nov 28, 2004
- 125
I have been running tests on the Renix electrical system of my AQ171 because of idle issues. I found that my crankshaft position sender is reading at 198 ohms which is within range for testing but it hits the 198 ohms and then drops down to 1 really fast. Is this correct or should it stay at a consistent 198? I pulled the cable off the engine and it appears to have been repaired at some point. It looks to have had a crack in it that was glued. When the engine is running it is at 10 degrees btdc. I just want to be sure the test is correct or if I need to replace this. I have replaced plug wires and I just do not want to start replacing something unless it is needed.
