I think I know whats going on but wanted some other thoughts. 1986 ER 120, was running good at top end and and low speeds. I had a problem with 1/2 - 3/4 throttle and stalling. I added a can of seafoam to a full tank of gas. Motor had been fogged and I had the same plugs in there when I added the seafoam. Took her out and bombed around and operated as usual.
It was on the 2nd outing a week later that it now spits and cuts out at full throttle. If you back off to 3/4 throttle it runs fine. I wonder if the seafoam has loosened some crap and plugged a jet. I'm going to replace the plugs next weekend to see if that helps. I'm still on the same tank of gas that had the seafoam in it. The gas also had a stabilizer in it from the winter so I'm going top it up with fresh stuff.
Anyone else ever noticed issues after using seafoam?
Thanks
Thanks
