Battery or charging electrical issue - 35 HP Mercury Outboard - 1988
rstier
Hi,
Could someone point me in the right direction. I have a 1988 Mercury 35 HP Outboard. The battery was new last season and I kept it on a battery tender all winter. I launched this weekend and the battery keeps running dead. I am wondering if it is a charging issue (rectifier or other)? I tried disconnecting both battery connections and the outboard continues to run which I assume is a good sign. While they were disconnected and the motor was running, I did a voltage check between the positive and negative terminals. I get no DC reading. What next?
Thanks!
Ron
aussieflash
Re: Battery or charging electrical issue - 35 HP Mercury Outboard - 1988
Never Ever disconnect battery while outboard running.Will damage ignition and various electricals.This should never be done with any engine.
rstier
Ok, that was a bad move. Any comments on troubleshooting this further?
Thanks,
Ron
Laddies
Banned
The quickest way to check output is hook a volt meter across the battery terminals start the engine and see if you gain voltage. otherwise check for contiuity between the 3 yellow wires at the rectifier (disconnected from the rrctifier) and here's the rectifier test.
rstier
Perfect, thanks. At least the rectifier is easy to get at on this one.
